maybe I’ve found a bug in v1.9.
We’re running an IDR32 with Laptop and a Behringer BCF2000 as cheap monitor console. Everything works fine, except 2 things.
- If I press a mix button on the BCF to activate mixmode on a stereo aux send, the pan potis are not displayed in editor.
If the mix button is clicked with the mouse, it works.
- If an mix is activated via BCF, the actual fader level of an fx-return, which feeds this mix, is not displayed (the fader stays down). If the mix is activated via mouse, everything works: the fader flips to the correct position. The fx-output is not affected, signal is going out all the time - so it just seems to be a display problem.
Any suggestions? Did anyone experience the same?
Thank you.
Hendrik
