thats it, i recorded (USB AUDIO) wich is obviously a stereo track in 92khz 24 bit,
but when i take out the stick and put it into my computer - nothing there - (see pic attached)
putting it back into the d-live it is there
anybody out there?
can you play your recordings in the console?
Is it Mac or Windows you’re trying to read it on?
that is the weird thing I CAN!!
i can see them and i can play them
i thought maybe the (wav) header is missing and the console for some kind of linux reasons can see it,
but no not even the rec folder is seen on the pc, and yes my pc is standard on “show hidden files”.
as you can see in the picture (see 1st post) there is a file called USBREC (32 kb size)…
that’s the folder… windows thinks it’s a file… and doesn’t has access to it
“Is it Mac or Windows you’re trying to read it on?”
win 8 and win 10
maybe it is a formating problem allthough it is the same stick with my muzak on (pause music)
wich i used for the last years…
let me try a different one quick…
Best practice is to have the surface format it, instead a computer. And not all USB devices fully work with dLive.
yep must be a formatting problem, tried a different one and it did it…
weird, the one that did not work was “sitting” inside the desk since w ve got it (almost)…
“Best practice is to have the surface format it, instead a computer. And not all USB devices fully work with dLive.”
i know…maybe the update to 1.9 did something to it as it has been formated on the d live (i do that since the ILive days).
thanks
Good deal! Sounds like you checked all the boxes right! ![]()
