Hi All. Made a gig last Saturday with 2x DX168 connected to SQ5 monitor desk using the add slot SQ-Slink Card, all preamp shared to the FOH SQ6 via the built in Slink network from the SQ5. Both consoles and laa apps running 1.6 and we had very strange behaviours:
1- The showfile/scene used was previously configured so the DX168 were connected to the SQ5 using the built in Slink port. We installed the SQ-SLink card in that console and change the routings to the channel inputs but we lost all the gain settings as if the channel gain setting was not sent to the stagebox via the new SQ-SLink port. We had to redo all our gains!
2- We had some analogue inserts plugged onto the SQ5 rear XLR inputs (compressors outboards) and in the new setup, so inputs (comp return) did not have the correct input level value. We had no time to check but I bet that if physical input 2 was routed to a free channel, it would exhibit a 10 dB difference with input 1. No time to diag, we removed our insert.
3- When adjusting preamps gains from the Mon SQ5, the gain pot turned properly but the audio gain was not real time adjusted and was jumping from the old to the new gain position without following the pot travel.
4- Can someone tell us was is the exact sizes for the SQ port screw looks like this torx is NOT Metric. PLEASE USE METRIC!!!
Are these known issues?
