2xSQ + Qu-24. Who will be the master clock?
I want connect 2xDX168 - SLink - SQ-Rack (MON) - SLink card - SLink - SQ-6 (FOH) - SLink card - Qu-24 (Broadcast)
Is it possible to connect using this scheme?
Who will be the master clock in this case? Currently, in the MON+FOH configuration, sq-rack master, sq-6 slave. But the documentation states that when connecting SQ to Qu, the master must be Qu.
The problem here is, that the Qu does not allow an external (S-Link) clock source.
Qu24 master, SQ-6 slave, SQ-Rack slave?
Yes , you must follow the chain through the SQ6 to the SQ Rack, I shall be using my SQ5 with my Church’s QU32 and have tested, knowing full well it should not work, not syncing the SQ to the QU, and while audio does pass, dropouts are almost constant. When QU is master there was perfect sync.
