A couple of questions
I reformatted a few weeks ago after it first happened and was ok for a couple of weeks then started doing it again. I’m beginning to wonder if it might just be the drive. It seems to work when it wants then other times it doesn’t
I’d suggest to try a different stick. You’re hopefully aware that flash drives degrade over time and may take longer to store data now and then. Maybe too long for the Qu, which then simply give up.
The thing is, it’s not that old we are only a 6 month old church so it shouldn’t be bad, but I know they can fail. so maybe that’s all it is
“old” for a flashdrive isn’t measured in terms of time but usage.
Not sure about the intended performance of that rugged flashdrive but audio streaming requires some guaranteed data rate over time, even for stereo recordings. Trying another stick should make things clearer…
