A&H QU-24 - Live Application with Logic Pro
Hello! I intend to purchase an Allen & Heath QU-24 and I have some doubts.
First of all, I would like to clarify what I will use for live applications with coral microphones, acoustic instruments and audios recorded in Logic Pro.
The actual instruments are: bass, guitar and acoustic guitar.
My question: some instruments like: drums, pads and click covers are recorded and are played by Logic Pro - they are already recorded, they are only played. So, does A & H reproduce via audio the audio that is recorded in Logic simultaneously to the real instruments? Can these recorded instruments in Logic Pro be addressed to some QU-24 channels?
Example:
Channel 1: bass (plugged in);
Channel 2: guitar (plugged in);
Channel 3: drums (USB - audio from Logic Pro);
Channel 4: click (USB - audio from Logic Pro);
Channel 5: acoustic guitar (plugged in)
Remembering that the application is live, then all channels will exit the main L/R.
Sorry for the mistakes. I’m using google translator.
Hello William,
Qu mixers support playback from local inputs and/or from USB so I believe you should be able to:
  • Connect computer to Qu24 using USB-B cable
  • Setup logic options/preferences to connect to Qu24
  • Set channels 1, 2 and 5 to use local source (XLR input on rear of console)
  • Set channels 3 and 4 to use USB-B source (audio streaming from computer/logic)
All channels will then output through LR mix.
Can someone who has done this please confirm this is correct?
Jake.
Thank you very much, Jake. I was afraid the QU-24 would not make channel-by-channel USB selection. For example, the Midas M32R - where selecting a channel to be used as USB implies the entire 8-slot USB slot, making it impossible to use for actual plugged instruments. Anyway, I’m grateful for the answer.
There is a Global setting for the USB source (Either the rear USB port or the QU-drive), but the channels can be set individually to either USB or Local source.
