A small jewel that needs to be refined further
Hello, I have a CQ18T and I think it’s a great machine, but there are some key features that need to be implemented.
  • Choose if the aux faders should follow the main fader.
  • Add slope to HP/LP filters
  • Add predelay to reverb effect
  • Add EQ to bus fx
  • Switching off/on of the effect flow with an on/off command instead of using the
    rotary selector (this is useful for not changing the set value).
  • Access the parameters of an effect also directly from the ‘SEND’ section.
  • The DX rotary selector should be associated with the main volume fader when you
    access the ‘Fader Section’ and until you select another parameter from any other
    menu.
  • Groups
  • Dca
Thank you
