Can someone provide an image of the AB168 in a rack? Does the AB168 require 4 rack spaces?
I see no responses. The 168 is 15.4 cm high and a rack unit 4.45cm so it is less than 4 RU. I did not find specs on the rack mount kit.
Sent from my Pixel 2 using Tapatalk
Yes it is 4He
See here for the picture.
At the moment, Thomann have the AR2412 (which is only 3U and does not require a kit to mount it) cheaper than the AB168, so if you’re rack mounting, that seems to be a much better bet.
