does anyone can tell me about gigaACE maximum safest cable lenght between desk and mixrack? was tried and can confirm?
For example midas/behringer manufacturer telling 100m, but in real world not more that 50m.
so how it is with GigaACE?
All our transport protocols are Ethernet Layer 2 compliant and tested to work with 100m CAT5e (or higher) STP cables.
To the best of my knowledge AES50 (as used by Midas) uses the Physical Layer only, not Ethernet packets, which might explain different cable spec or performance.
A&H is recommending 100 m at the maximum, but I successfully used 130 m Cordial CAT7A Long run in the past.
Never had problems with cables shorter than 100 m.
In reality, I already had the following:
From the mixrack to a wall connection on stage 20m CAt5e, then 73m CAT7 house cable, 1m patch cable at the patch field, 25m CAT7 house cable to the FOH floor tank, there again 5m CAt5e to the surface.
In total 124m
I have used this several times and it has always worked stable.
Of course, this is no guarantee, but it shows that the system works quite well.
If you use a pair of giggabit media converters even running Multimode you should achieve 550m between ends plus the length of the link ethercon cables. I think there is a note in the A&H help files about this.
