Action to spill a specific DCA
Hi!
Would be great if there would be an action and/or soft button option to spill a specific DCA.
Best,
D
There is already a softkey option to spill a specific DCA onto the surface. Using this functionality means you don’t have to have the DCA fader located on the surface, thereby freeing up a channel “slot”.
How can I spill a specific DCA with a soft button? Can’t find it in the list.
Best
Mix Button of that specific DCA
I asked for a soft button. For the mix button I have to have the DCA on surface. :slight_smile:
Best
Assign the MIX button to a softkey. It does what you want.
It didn’t in director, but I will try on the surface.
It does the same in Director.
There is a global switch to enable DCA spill or not. If that is off, no DCA will spill the channels.
Ahh, that’s the trick. Thanks!
