adjust one mike in two outputs easier?
Is there some way to route things , perhaps with a custom layer or DCA or combination of features,
so that we can adjust one fader to adjust the pastor mike in an output as well as LR in house at the same time?
Our current set up requires us to slowly ride the fader as the preacherman gains steam during the sermon.
But that means we have to go to the mix78 that we currently use and also adjust his loudness for the livestream and AM/FM feeds.
This is an all volounteer operation with some more or less advanced amateurs but it would be easier for some (most?) to be able to make this adjustment with one fader and not have to do two of them.
If the send on mix 7-8 is set to post fade on the pastor channel it will track changes made on the main mix.
Once you set the relative level on the mix send, maybe bumped up a little for the stream feed and it is set for post fade that mix level will track fader moves done to the main mix.
Actually maybe you should post fade for all of mix 7-8, once the mix 7-8 balance is dialed in all the overall mix will then follow the main mix then.
It may not be perfect but it’s decent compromise short of having someone indepdently actively mixing the live stream mix.
@mikeC
Thank you!
