I suggest a DX expander like the DX012, but for Inputs. Also with the possibility to switch to AES Inputs with SRC.
Till now the only option for AES Inputs is a DX32 Expander, which is an extremely space consuming solution.
Thank you, I know these. I have the 10 Out AES Card in my dLive System.
I my case all the I/O Ports are full (Dante, GigaACE, AES Out).
A DX120 (or whatever you would call it) would also be a great addition to the AHM to make it more suitable as a system processor, especially with the new features in V1.5.
Mainly I would use these inputs to connect other consoles to my system. At the moment that has to work via analogue inputs.
For AHM this would be a great addition to use it as a system processor e.g. to connect several mixing desks to sum them up in the AHM.
Honestly, if AH gets around to something like that, it should probably be in the DX88-P format. Heck, ‘just’ make a DX88-AES and be done with it. Great for installs etc. Then you can have 16x16 AES in a single rack space.
