I’m doing some upgrades to the audio system this fall and I’d love to be able to go AES from the iLive to my system DSP. To cover all my mains and fills I need 10 channels of output. How do I get from my current system to AES (or SPDIF)?
That upgrade path sounds like a fantastic idea if it comes to fruition.
I had been planning to use a MMO with an IDR-Dout in the next few months to acheive what you are trying to do but I might hold off a bit longer.
The problem I have with the MMO option is it takes up a port B slot which is fine most of the time but when we would need to digital split we are going to have to move cards around a bit which ok but not perfect.
Teknik that is my problem exactly. If I put an MMO card in my iDR-32 then it displaces the Port B Ace card I need to run my xDR. I suppose I could buy a 2nd xDR run both xDRs from the Port B Ace and install an MMO in one of the xDR-16s. That’s even more gear to buy!
No… I use an MMO card with the iDR-DOUT into some iTechs. Just two network cables to the DOUT… one for audio and one for metering data. And of course one AES connection to each amp. And you can run two DOUT’s off of the MMO card for 16 channels.
Does the iDR-DOUT require an iDR-4?
The XDR has a “B” port so as I understand it you could put the MMO in the XDR negating the extra gear requirment but if for instance the XDR is at FOH and your IDR-Dout is on stage you would need more cat 5 cables to run back to it.
No straight out of the IDR-Dout to whatever you want to feed the AES into.
The documentation confirms this and Sam from A & H has also confirmed previously
… future improvements will be aes/ebu outputs on the mixracks - this can be done by upgrading the pcb or directly when ordering …
(info from the last gld/ilive workshop i visitied 2 weeks ago )
Is this true?
If so, please add at least two, better four to eight AES/EBU inputs as well! Many musician use digital equipment, too, like AxeFX or digital wireless mics and I think it would be beneficial to the sound to use their AES/EBU out to stay completely digital.
What about using Dante, would give you 64 channels to play with and there is plenty of Dante equipped processing out there.
If I remember correctly if you included a giggabit switch could you still do your digital split? Not sure about that but I am sure more learned scholars than I will correct me.
From my point not all speaker manufacturers dedicated speaker processing is currently AVB compliant and hence can not simply be implemented into a Dante network.
True I could go out and replace all my current speaker processors with something like one of the new Lakes and then try and get it to give the same results that the speaker manufacturer wrote in to their processor.
Its a lot of money to spend for a somewhat dubious outcome when having the simple abilty to go from the Ilive in AES directly to existing proceesor gives a predertmined outcome.
In the future when everyone is following AVB and all manufactures follow the protocol yes DANTE all the way.
