When the AFPL IEM (controlled by fader) is patched to Mixrack outputs the pan/balance function doesn’t work correct. For example if I pfl a stereo aux and change the pan of a channel sent to the aux the pan follow correctly when panned to the left but when panned to the right there is still some audio in the left channel. This is only true for the assigned outputs in the mix rack. The phones output and the AFPL bus (not controlled by fader) works correctly.
/Henric Isén, Sweden
