Alt Out trouble?
Hi guys,
Someone help me about a trouble with the Alt out channels on Qu-24?
The right channel has a crispy sound when I select LR output when I connect studio monitors.
This channel sound lower than left channel.
But when I use the LR Pre, the sound is fine for both channels. Why?
Just in case you didn’t already checked this: Maybe bad adapter? Alt Out is TRS, LR on XLR.
If the master fader is at unity then the pre/post signal should be identical (assuming there are no inserted FX, EQ, compressors etc. on the main mix)
Does the same happen with other mixes?
Where is the output balance on the LR channel? Look at the first tab in the routing pages with LR selected. LR pre is unaffected by this.
Let me try. And, I write back!
