AMM configurable Out´s
In the I / O patch can select the outputs of the various configurations of the AMM.
For exampe, if seleccion TWO AMM in the setup, the I/O can be LR that first AMM and LR to the second AMM.
what is the request? I don’t understand…
you can still use the channels for routing and processing
Yes, that the AMM work as zones or independent.
+1
Suggestion-AMM.pdf (96.1 KB)
the AMM does not route any audio…
routing depends on the channels
so if you need different zones it’s easy to route the channels from one AMM to a subgroup
and route this subgroup to a matrix for a dedicated zone
you now have the possibility to use 4 complete automixers
wich send their signals to a single zone
