Anyone Using GLD Editor on Large Touchscreen for monitors?
I meant to say:
PC Large Touch-screen
Still no-one?
OK
what about anyone using GLD Editor on a PC LARGE TOUCH-SCREEN?
Look forward to your comments
NZdave
I don’t know if my 15" laptop touch screen qualifies as large or not–but whenever my church lets me out of the FOH booth to play bass I’ll generally mix my own wedge running Editor on the laptop.
In general I’d say the slider controls on the iPad apps are more touch-friendly than the rotaries on Editor; I almost always end up tweaking with the touchpad on my laptop rather than the screen. Plus the iPad’s a lot easier to bring out in front of the wedges during rehearsal to quickly tweak as you can hear your changes.
Be aware as well, that if you’re thinking of a high-resolution display, that the Editor window cannot be resized or maximized–so you could end up needing to crank your monitor resolution way down to fill a decent portion of the screen with the Editor.
In short, unless you’re in a really hostile environment for WiFi or absolutely need feature access that can’t be done on the iPad apps (such as FX engines) I think you’d be better off with iPad.
I use it on an 13.3" Asus touchscreen. I found out that the GLD software doesn’t work while the screen resolution is 3200 x 1800, but I have to down-grade the screen resolution to 1366 x 768 and reboot the screen. Then it works on the 13" screen.
I also have a Dell U2711 ( 2560 x 1440 ) and if I use it with GLD Editor, it again doesn’t work. So I then down-graded it to 1600 x 900 and again it works just fine.
So hope this helps.
