I know the AB168 is a new unit for GLD and QU Mixers, but my question is does anyone know and tested the AR84 dSnake to the AB168 for the QU-24? I don’t want to spend the money, and then have it not work. I see in the notes it states you can use the new AB168 with AR2412 for the QU-24, but the AR84 and AB168 with the QU-24 would work much better for my application. Not to mention, the combo would have the combined number of inputs and outputs as the AR2412.
My application would look like this. AR84 Expander to AB168 Expander via Cat5. AB168 dSnake to QU-24 dSnake via Cat5. 8 Inputs/4 Outputs from AR84, 16 Inputs/8 Outputs from AB168. Would this be possible, and reliably work?
Hello Nicola and GCumbee
1.5 is a Wonderful update!
Ihave4 of these QU’s and eventually another 3 XQU32 by Christmas (hopefully)
I have 3 of the AR2412
I want to use one of the AR2412 each side of stage by speaker stacks. Really just the sends. NOT the input lines although that would be brilliant is I could mix portions from the different AR2412 inputs
I plugged 2 of the AR2412 in to QU16 and see there is no provision for this?
Is that correct?
Or am I just imagining A&H have left something out here?
I don’t think that configuration’s covered by what Nicola’s mentioned. This post suggests that there’s only 20 outgoing channels available to audio racks anyway.
Thanks for your reply Mervaka, however
That’s not my point!
I come from a little place down under on this planet where you have to think outside the square.
I already own 3X AR2412 and now I’m faced with going to collect the last AR08 (in stock)(i think its called that) to be able to simply put a distro box across the other side of the 18 meter stage where I need 4 sends.
It would be great to just assign those outputs to where you want them to go on the stage.
I’m the guy that got caned every month at high school for smiling man!
I don’t “always follow the rule book”
innovation is the name of the game.
Dave. With all due respect. I think it is clear by the examples Nicola has put forth that you scenario does not work. There is nothing in the design for 2 AR2412’s to work. I have never tried but I would guess the console will not recognize the second one. It will recognize the new AB1608. I think you are going to have to settle for that unless they change something in the firmware.
Thanks guys.
I appreciate your feedback
I see it as an opportunity missed!? whats that old saying? what could have been
How can I get a job on the design team?
I’m caught between a rock and a hard place here.
All of this great equipment but not quite the right connections!
I had to go get the very last AR84 one in NZ!
My summer run of events starts beginning of September.
I don’t think the QU32 will be here by then which means…
I’m going to have to use my 3 X QU16’s as a one desk or drag my GSR24m out for a major job I do. And that means having to take 8 X 31 band EQs and compressors out into the field.
Frustrations!
Actually I quite like using 3 XQU16’s
I get 3 of everything. 3 screens. and 48 faders…
The draw back is using the GEQ’s.
That fries my brain.
cheers
whats about an analog snake? if the only reason is to get 4outputs on the other stage-side…! 20m 4CH analog snake!
EQ’s are easy to use on the Qu! While setting everything you can use the GEQ and during the show you can use only the PEQ - that’s fast and after every band you can reset them to have your standard-setting back!
(Maybe there is a possibility to rent a GLD with an additional AR84 Rack - then you’re definitely satisfied!)
Thanks eotsskleet for you thoughts and ideas.
Yes analogue cabling. I have enough of that stuff to circle a Large Arena or stadium of which I have been doing once a year for last 7 years.
However this year I was advised to use technology where possible and also to make life easier for myself!
Its all of that "perception stuff " business people use.
Anyhow today is a brand new day!
I’m 59 in a few days so I need to relax the blood pressure :+)
And go check out a cough Behringer XT … as I work with a guy that uses one later this year on a very large event doing monitors.
I need to bring my knowledge up to date.
I do not want to get a GLD.
Not enough surface area and a few other things…
Cheers
dave NZ
“not enough surface area” for a GLD-80? I thought you would use 3pcs. of Qu-16 if you don’t get your Qu-32!?
What is a Behringer XT? I couldn’t find that in the internet!
hey dave… i will visit you in march or april next year OK? I’m from switzerland but start my worldtrip for more than a year on 4th of september 2014! Then we can talk about “possibilities to make life easier!” ;D
