I recorded the LR in my QU but in the end I did not stop. Now I have the file with 3gb but there is some way to recover the audio?
Can someone help me?
If you are on Windows then the procedure is described here:
Why do my Qu-Drive recordings appear corrupt?
In any case you need some utility which reads RAW PCM data and adds a correct WAVE header.
Thank you, I have osx, but I will try to follow the procedure in the windos
Thanks Thanks
Solved my problem;)
thank you
