Auto Mixer Meter Point Issues
Hello,
I’ve noticed that when attempting to use the automixer, all the channel meters ( LED and on screeen ) are post AMM which is in the wrong place. When mixing a discussion it’s imperative to be able to see the level meters on other channels pre AMM.
I seem to remember this was a problem on the dLive and it’s been resolved now.
Can it be resolved on the SQ also?
Hi!
The AMM gain is at a fixed point in the signal chain on SQ, this is Post Delay and Pre Meters. You can find the block diagram of this here: https://www.allen-heath.com/media/SQ_ReferenceGuide_V1_3_0.pdf#page=88&zoom=250,-76,552
Although there are no plans for this to change on SQ currently, you could add this to the feature suggestions forum for SQ and it may be considered in the future.
Alex
Thanks Alex for your reply, much appreicated
Its the metering that is in the wrong place not the AMM, it sadly makes the AMM all but useless for a lot of conference applications, and really is quite a bad error, so it would be great if it could be looked at.
Thanks.
