Automatic switching of NEQ12 strip rotary (PEQ mode)
I wonder if it would be possible to operate NEQ’s 12Band PEQ introduced in Avantis v1.3 with Strip Rotary.
Currently, when Strip Rotary is in PEQ mode, even if the NEQ 12Band PEQ screen is displayed, it is the 4Band PEQ that was installed from the beginning that can be operated.
When Strip Rotary is in PEQ mode, it would be smoother if it automatically switches between PEQ and NEQ (12Band PEQ) depending on whether the selected output channel is PEQ or NEQ (12Band PEQ), but in v1.3, even if the NEQ screen is displayed, it is PEQ that can be operated, which would encourage operation errors. This can lead to operation errors.
The 12Band PEQ of the NEQ also has 3 EQ points, so the Strip Rotary has 3 12Band PEQ points… In other words, the 4Band PEQ screen can be used.
If you can display a circle, triangle, or square anywhere on the screen, you can determine at a glance which EQ point is in the NEQ.
Please consider this.
I am looking forward to the next version.
+1
a good idea.
also, while editing on the regular 4 bend PEQ the mian knob is automatically the Q. but not on the NEQ. it would be glad if this can be fixed on the next version.
