Auvitran Network ASIO Streamer
Does anybody have any experience with this? What do I need to do to be able to use it?
We got a ILive 144/iDR10 (RAB1) system… And if possible, what is the channel count for the ASIO streaming on this unit?
“If bad sound were fatal, audio would be the leading cause of death”
:wink:
Hi Resthill
I am afraid the RAB1 Auvitran AVD module will not support the Auvitran Network ASIO Streamer. Only the new AVDM (M-ES-V2)module supports the Auvitran Network ASIO Streamer via the 3rd Port.
You will need to Purchase a RAB2 Module and a AVDM (M-ES-V2)module
The channel count on the ASIO driver is upto 64 Channels Bidirectional and is supported on Windows XP, Vista and Windows 7 32 & 64Bit) (Not Mac OSX)
Regards
Sam A&H
quote:
Does it also work with the M-ES-V1-BASE-A upgrade of the old ES module?
Thanks and greetings,
Walter
Hi Sound
No i’m afraid the upgrade kit M-ES-V1-BASE-A does not support the ASIO streamer, this is because you are still using the older EtherSound AVD module. Only the new AVDM (M-ES-V2-A)module will work with The ASIO streamer.
Regards
Sam A&H
