I have noticed that if I change the label of an Aux, the label does not update in the Mix bus Config screen. If you change the bus from its mono/stereo state and apply the label then updates. Changing the bus back to its desired config then puts things back to normal. I also noticed a small Audio interruption on my main buss which was not being fed by the Aux in question.
thanks
