Aux Mix1-8 Select Buttons - Non responsive
Hey Everyone,
The Mix Select buttons are non-responsive. In other words, I can select the LR, or Groups 9-12. But Mix Select buttons 1-8 are non responsive. I also cannot select the mix1-8 on the touch screen of the mixer either. The only workaround short of power cycling the whole mixer (not an option during a live show) was to save the show/scene, then recall a different show/scene, select the mix I wanted to use, (mix1 for example), then go back and recall the actual show/scene I was working on. It would allow me to mix within that selected mix as long as I wanted. But I selected a Group 9-12 or LR, then I would have to start all over and go through the workaround again. The Mix1-8 were not working.
Does that make sense? Kind of strange right?
Details:
SQ-5.
Firmware 1.2
AB168 Connected.
Wifi Router and iPad connected.
I feel like this is repeatable as it has happened more than once. Maybe I can take a video and show you what’s going on.
Any advice or Tips?
Has this happened with anyone else?
Hi DJ Swell,
Could you start a ticket at support.allen-heath.com and we will look into this for you.
Alex
Is there an update on this? I had the same problem today.
After some troubleshooting: the probleem seems to occur when you have the GEQ open on the flipped faders on the L&R and then press one of the mix knobs OR when you do a reset of the GEQ (either a mix or the L&R). Loading the same scene or rebooting, solves the problem.
Apparently they managed to deploy a fix with Firmware 1.2.1, at least that’s what the release notes suggest.
