Aux on post
when ever i update my firm fare i really hate to go to every aux and make into post so is there one button which will allow me to makes all the auxes post /pre
Save this as a scene
SRV-AVB
R-72, iDR-16, xDR-16, Dante
nop its not working i did that earlier
Before you update your firmware, archive your settings as a User Show (Utility page / Show Manager). After you update your firmware you can recall that User show or a Template show to get you back to a known starting point.
Yes, there is one button to make all 64 channel sends for an Aux pre or post. Press MIX for the Aux, then hold down the PRE/POST FADE switch and press the Aux master strip SEL key once or twice to toggle Pre or Post for all channels.
Hope that helps,
Carey
Hi Carey,
Is that solution for the ‘global’ pre/post only when using a surface? I also find it quite irritating (and time-consuming) to change all the pre-posts for all my Auxes …
Cheers!
Guy
www.pianojam.nl
You can do a right click on the aux bus.
Routing>All Pre!
