In most analog consoles there is option to switch pre fade auxes pre or post channel EQ. This is done for each channel separately.
Any chance to do same thing on iLive?
ddff
ddff
You can choose the position of the aux, Post-PreAmp, Post-Gate, Post-EQ, Post-Comp and so on… You can do this seperately for every aux.
Using & For Rent
iLive T112 / iDR48
quote:
Originally posted by ThomasLYou can choose the position of the aux, Post-PreAmp, Post-Gate, Post-EQ, Post-Comp and so on… You can do this seperately for every aux.
although, it can’t be done for each channel…it’s global for each aux only. I guess it would need something like the “global direct out” selection on every strip…
RayS
R-72/iDR32/iPS10
Yes, this would be helpful in some situations. Basically, when mixig monitors from FOH.
Hope they put that option in some of next firmwares.
ddff
I know this is an old thread… but curious…
My understanding is that the Global settings are for the input direct outs.
Is there a way to set the Aux outputs to be pre-eq?
T112, iDR48, M-DANTE, PL10, MixPad, Editor
MacBook Pro, Mac Mini
Lion/Logic Pro
All latest versions/firmware
hi clarocque,
yes - switch the routing button
then SEl Button from the AUX
now set the setting in the popup menu on the right where it says
AUX send
regards joe
iDR32 + IPad1 + Laptop
*** less is more ***
Thank you…
Lion/Logic Pro
