Suspect the answer to this would be obvious with a console in front of me! Is it possible for some channels to send to a monitor mix post pre-amp (ie completely unaffected by any EQ or compression) and some post EQ. I see these options on page 35 of the user reference but they would appear to be global parameters that apply to all sends to the aux bus, is this correct?
Pretty sure it’s only global.
Hi @msonix,
The Direct Outputs are globally set, the Aux send tap-off point is set per mix (so not ‘global’ as each mix can be fed from a different point in the input channel).
If you need to send from two different points in the input channels to a single monitor feed, you can use two Aux mixes (with different settings), then combine these using a Matrix to send out to the monitor.
Cheers,
