Hey, so im needing to adjust my gain sent to my DAW from our Avantis → Dante → DAW.
How abouts might i go about adjusting these levels? (We purchased the Luke Hendrickson Template from Productiononline.com and the template requires audio stems to hit a certain gain level in order to work with template correctly with gates, compressors, etc.)
What you mean with “purchased a template”?
This gain is set at the preamp level. The standard is to look at your meters and set the channel gain to average at the high green - just peaking into the yellow on loud parts. If you do this, I suspect your DAW settings will work as expected.
Never mind…found it myself… what a rip off, I’m shocked
a ProTools template for $500
and what he is promising
