We have the firmware v1.13 and everything was working for 2 weeks and then today… The board, levels indicators, buttons, rotaries, everything freezes for about 5 secs for 5 seconds and then works again for 5 secs and over and over and over…
For instance, the RTA meter will freeze for 5 seconds, then animate for 5, then freeze, etc.
When the board is in the active 5 second state everything seems to work. in the inactive 5 second state all the rotaries and faders seem to make their adjustment which is then applied as soon as it unfreezes. However, mute buttons and soft buttons only work and toggle their function when in the 5 second active state.
Do you have any IP controllers connected to it? I have seen the same issue and when i rebooted an IP1 controller and it was solved. you can test by disconnecting the controllers one at a time.
We are seeing this behavior with a single IP8 connected - I believe our board is on v 1.13 as well. I see this behavior listed as known issue ID1031 in the v1.03 release notes, but it is not listed under v1.10 notes in either the Fixes or Known Issues list. Seems clear it should still be listed as a known issue right?
