I’d like to see an AVB compatible card for these systems. I’ve been doing more and more corporate stuff and a lot of the systems I need to interface with are using AVB (I wish it was Dante but that’s another discussion…). Right now I either have to rely on AES67 or buy a $5000 converter that does AVB to Dante or drop it to analog. Does anyone know if the Dante cards for the SQ (which I’m assuming is the same as the new form factor for the dlive) will support AES67?
Dante is already supporting AES67
but it depends on the vendors of the products to update it to the level of AES67 compatibility.
https://support.allen-heath.com/Knowledgebase/Article/View/1172/103/how-can-i-enable-discovery-between-dante-and-other-aes67-protocols-q-lan-ravenna-livewire-etc
https://support.allen-heath.com/Knowledgebase/Article/View/1171/103/how-do-i-enable-aes67-on-my-m-dante-module
Thanks Steffen, That’s good info to have. I knew the vendors needed to update the firmware and I wasn’t sure if A&H had done that already or not.
