Hi. I was just wondering what effect would it have if I use an unbalanced cable to a digital stagebox like the AR2412 or AB168.
I know about the distance and noise that long unbalanced cables get, but what if I use a short unbalanced cable to a digital stage box and the stage box is connected to the mixer via a long ethernet cable.
The stage boxes are all balanced XLR inputs. To go truly unbalanced in you would need to use an XLR cable that has pin 1 and 3 tied together.
How many channels are we talking about?
Just use a DI box.
Balanced or unbalanced input connection it does not matter once it leaves the stage box on the D Link cable.
It’s just for a cheap wireless IEM system that has unbalanced stereo input. I did build a cable with the XLR 1 and 3 pins connected but I haven’t tried it out.
I have an AB168 and I’m planning to attach a short custom cable - 3.5mm TRS split to 2 XLR (stereo unbalanced). I wonder if there’s gonna be some weird effect on the sound because of the unbalanced cable, though it’s just really short, like a few inches from the stage box.
If you are trying to connect unbalanced IEM to an output of the AR/AB, then there is no necessary to bridge pins 1 and 3 - there are no output transformers. You can use just pin2 referenced to pin1 and that is it. You’ll have -6 dB on the output comparing to what VU meter will show on the mixer.
Einars
That will work but be careful, with that it would be possible to send 48 volts phantom back into the devices headphone jack and that could kill the headphone output.
Thank you for the reminder.
