This testing was one I intended to do long ago, but re-inspired from Neak’s post that included running Dante over the GigaACE link.
As A&H advertises it, the network connection between the MixRack and a Surface is a lower bandwidth link designed for management systems that may include Director, IP8’s, Wireless management and other systems that are now part of a regular show. It does this well, as long as you remember it has bandwidth limitations and latency. Audio does not travel well on it reliably, as noted below, but appears that it can be done within limits.
Observations of GigaACE :
- Network bandwidth is shared with the console control of the MixRack. Over-utilization will cause the console to lag.
- About 22% of the Gigabit bandwidth that you have vs a direct connect
- Appears to not honor TOS/Prioritization, so latency-dependent traffic is subject to wild latency swings and dropouts due to network traffic between the surface and mixrack or other devices.
- Dante/Audio is directly impacted (tested, below). You can’t run reliable < 5ms latency.
- MIDI/rtp will be likewise impacted if it is being used for anything timing-sensitive (MTC, Clock)
Show recall timing (Util/Show Manager/Recall):
- Nothing on network: 12.2sec
- Full bandwidth test: ~44sec
If you have any questions on the testing I did, feel free to ask.
Jay
Environment:
- Cisco SG300-28P Switch, VLAN 11, Configured for Dante QoS/TOS
- MSS 1448 on all bandwidth tests
- 2 MacBook Pro’s. One direct to console, one via cisco switch at mixrack
- dLive S-5000, DM64 on V1.40
- Yamaha TIO 1608 for 2nd Dante device via switch at mixrack.
- Using iperf3 -V -Z -t 600 -c 172.30.11.100
Direct Connect
[ ID] Interval Transfer Bandwidth
[ 4] 0.00-1.00 sec 110 MBytes 925 Mbits/sec
[ 4] 1.00-2.00 sec 112 MBytes 938 Mbits/sec
[ 4] 2.00-3.00 sec 111 MBytes 931 Mbits/sec
[ 4] 3.00-4.00 sec 112 MBytes 938 Mbits/sec
[ 4] 4.00-5.00 sec 112 MBytes 938 Mbits/sec
[ 4] 5.00-6.00 sec 112 MBytes 938 Mbits/sec
[ 4] 6.00-7.00 sec 112 MBytes 938 Mbits/sec
[ 4] 7.00-8.00 sec 112 MBytes 938 Mbits/sec
Via GigACE - no additional traffic load
[ 4] 0.00-1.00 sec 25.0 MBytes 210 Mbits/sec
[ 4] 1.00-2.00 sec 24.8 MBytes 208 Mbits/sec
[ 4] 2.00-3.00 sec 24.8 MBytes 208 Mbits/sec
[ 4] 3.00-4.00 sec 24.8 MBytes 208 Mbits/sec
[ 4] 4.00-5.00 sec 24.8 MBytes 208 Mbits/sec
[ 4] 5.00-6.00 sec 24.8 MBytes 208 Mbits/sec
[ 4] 6.00-7.00 sec 24.9 MBytes 208 Mbits/sec
[ 4] 7.00-8.00 sec 24.8 MBytes 208 Mbits/sec
Via GigACE
1 Bundle of Dante - Audio Dropouts < 5ms
[ 4] 0.00-1.00 sec 16.4 MBytes 137 Mbits/sec
[ 4] 1.00-2.00 sec 19.9 MBytes 167 Mbits/sec
[ 4] 2.00-3.00 sec 22.1 MBytes 185 Mbits/sec
[ 4] 3.00-4.00 sec 22.1 MBytes 186 Mbits/sec
[ 4] 4.00-5.00 sec 22.1 MBytes 185 Mbits/sec
[ 4] 5.00-6.00 sec 22.0 MBytes 185 Mbits/sec
[ 4] 6.00-7.00 sec 22.1 MBytes 185 Mbits/sec
[ 4] 7.00-8.00 sec 22.1 MBytes 185 Mbits/sec
Via GigACE
2 Bundles of Dante - Audio Dropouts < 5ms
[ 4] 0.00-1.00 sec 15.5 MBytes 130 Mbits/sec
[ 4] 1.00-2.00 sec 19.1 MBytes 160 Mbits/sec
[ 4] 2.00-3.00 sec 19.1 MBytes 160 Mbits/sec
[ 4] 3.00-4.00 sec 19.1 MBytes 160 Mbits/sec
[ 4] 4.00-5.00 sec 19.1 MBytes 160 Mbits/sec
[ 4] 5.00-6.00 sec 19.1 MBytes 160 Mbits/sec
[ 4] 6.00-7.00 sec 19.1 MBytes 160 Mbits/sec
[ 4] 7.00-8.00 sec 19.0 MBytes 160 Mbits/sec
