jozee
1
Hi
how can i achieve 120M cable to work between the surface and the mixrack?
I need the cable to be heavy duty so it will hold through a rough environment.
I thought of using ‘eurocable’ with 8 pairs, the that used in xlr’s multi cable.
any suggestions?
Neautrik Etherflex is pretty tough but if you want it to be tougher you could always use Pliosil braiding.
www.TotalLiveSound.com
Hi Jozee
Here is a link to the recommended cables A&H have tested upto 120m with ACE.
The Etherflex is one of the more rugged cables we recommend.
https://www.ilive-digital.com/cables.html
Hope this helps
Regards
Sam A&H
mr-b
4
Use Fibre Optic 550m in Multi-Mode can’t remember about single mode but I think it is about 7Km.
