can someone tell me...
how to change offline hardware configuration so that it matches my online configuration, it is set as an idr64 (which is wrong) and there is no option (that I can see) to change it
When you first launch the Editor, select the offline option and the first screen that apperas is a hardware configuration screen.
You can select the rack, surface, portB card and a few other things.
Once you are open, ,load your show.
Gil Parente
Design & Integration
Entertainment Arts, Inc.
iLive 176, T112
iDR48 , iDR16, iDR10
Multiple iPads
Dante
Etc…
I am new to the iLive, but I had a similar situation when first evaluating the software.
When I first installed it, it did not seem to matter what I selected on the initial screen. I think what I had to do was to go into the scenes area and recall the surface and mixrack scenes to make the software remember the configuration. This is the same that you would do on a real system when creating a new show.
After this it seemed to remember what I had selected. If you dont have the scenes for the configurations, use shows to load a new show from a factory template.
tspad1960
Remember the iDR is 64x32 regardless of how many physical sockets it has. The editor will show you 64 useable channels, even though you won’t be able to fill them with physical inputs and outputs. That may be the source of some confusion.
