Wounder if you can help…
I have a Waves Soundgrid server (Wave SGS) running with my SQ5. To date the Soundgrid has been 100% reliable but even with redundant servers a loss of the primary waves server means a period of no audio for any channels sending to and returning from Waves via a channel insert.
I’m trying to figure what might be the best ways would this.
What would be really great would be a immediate way to disable all inserts in the current show? Perhaps through a softkey. Is this possible?
I can save the current scene to a new scene say “No WSG Inserts” which, which has the required inserts OFF and I could launch this scene immediately if there is a WGS issue.
The “limitation” of this approach is that the “No WSG inserts” scene will not include any of the mix changes made in the primary scene after the “No WSG inserts” scene was created and saved.
I did think… “Oh, ok I can make the channels SAFE to preserve their mix settings” but this results in the channel’s insert setting also being SAFE / preserved which, for the failure scenario, is exactly what I don’t want.
Is there a better way to do this?
Thank you
