Need a little help. for some reason when I connect my Macbook with the Mixrack using cat5 wire it doesnt work. I can connect a regular windows laptop but not my Macbook. I’ve tried so much troubleshooting. Need some help.
In His Purpose
In His Purpose
quote:
Originally posted by nutleyalwcNeed a little help. for some reason when I connect my Macbook with the Mixrack using cat5 wire it doesnt work. I can connect a regular windows laptop but not my Macbook. I’ve tried so much troubleshooting. Need some help.
In His Purpose
As in a previous post, https://www.allen-heath.com/iliveforum/topic.asp?TOPIC_ID=1530 have you checked that your ip address is iLive compatible…192.168.1.10 and up or similar…if it isn’t, check system prefs/ network /advanced/ select dhcp with manual address and give it an ip address…also make sure airport is off when you are trying with cat5…
if none of these work please follow up with more details of how far you get before you know you can’t connect.
Hope this helps.
RayS
R-72/iDR32/iPS10
