CH to all mix on DCA fader spills DCA children while the button is pressed down
Suggestion for a new feature: “CH to all mix” when a DCA fader is selected spills DCA children to faders while the button is pressed down.
Currently pressing the “CH to all mix” button when DCA is selected doesn’t do anything.
also a good idea!
+1 That would be great. You also could use layer buttons for more than 24 channels assaigned to one DCA Master.
I will unpack “spills” as “displays the DCA members on channel strips, while the button is down” and +1 that as well.
+1
+1
I’m all for DCA spill/roll out, BUT I think this way isn’t a good way. Holding down to spill means you have to use one hand for holding down AND can only move faders will that is happening, because pressing SELECT on a channel would shift the function of the CH TO ALL MIX button. I’d say a user key and also a button onscreen when a DCA is selected for DCA spill on/off and if on then selecting a DCA will spill the channels.
+1 for dca spill/roll out. this is a absolute killer feature for mixing a lot of channels on a small 16 fader surface. i´m so used to that on consoles from other manufacturers that i feel very slow and clunky on every desk that doesn´t allow this. the other ones i know spill just by pressing the select button of the corresponding dca. simple and super fast.
So used to it on other consoles when doing musicals.
+1
+1
+1
+1
+1
+1 for DCA Spill
+1 This is what made me enjoy mixing on a Midas Pro 1. Smaller surfaces with higher channel counts (SQ-5) need DCA Spill!
+1
+1
Sad to see this request didn’t make the 1.4 FW. Especially for the SQ-5, we really need this for high channel count on a smaller surface.
