Change insert point
Hi!
I have a problem with my waves plugin together with my GLD80.
I have a GLD80, waves V2 card and a Soundgrid server. Everything works perfekt with my waves plugins.
My problem is that when i want to use a waves-plugin ex. DeEsser and i need to insert it it will be placed PRE EQ. I want the option to change the insert point so the DeEsser is placed after POST EQ, POST COMPRESSION, POST GATE.
Is it even possible?
Not that I can find, however you can make it happen if you have a spare mono group you could insert it on and route the vocal input to.
Chris
Yes i have also thought about that option but it is not a super great way to deal with it =(
Ex you want 6 DeEssers on 6 different mics or 5 multiband compressors on different inputs…
