Hi. I’m new to the forum. We have a GLD-112 for FOH audio and another one for livestream/recording audio. Currently the stereo audio signal from our iMac running ProPresenter 7 is sent to the livestream audio console, then down to the FOH console where it comes in as 47/48, but in one channel. We’d like to experiment with running our stereo tracks (click left/mix right) from ProPresenter 7, but with the current config, we can’t split the click from the mix, which causes obvious problems. How can I get channels 47 & 48 to be separate when they arrive at the FOH audio console? Is there a tutorial to watch, or an answer short enough to share here? Thanks for considering.
I’ll try these smaller files. Sorry.
Screen-Shots-GLD-112-FOH-21.01.05.pdf (78.3 KB)
Screenshots-GLD-112-Livestream-21.01.05.pdf (83 KB)
patch them to different inputs is just one possible solution
Thanks SteffenR. I took a look at it and cannot find how to separate 47/48 at the Livestream Audio Console.
you can’t separate the processing channels 47/48
but you can patch your I/O port sockets to other channels
