Channel compression not present in Post send to Submix
I am mixing 20 audio channels and sending the mix to LR for the live performance, and to Mix9-10 for the livestream. The channel compression is in the Post send to the LR, but absent from Mix 9-10 even though the sends to Mix 9-10 are all set to Post. The compression is needed for the livestream just as it is needed for LR. Adding compression to Mix 9-10 doesn’t work because one loud vocal pushes down the rest of the mix. Is this normal? Is there a way I can include the channel compression in the post feed to Mix 9-10? Also, of note, the ST1 input channel compression is included in the Post feed to Mix 9-10, just not channels 1-20.
