Channel delay not transmitted to Monitors Mix
Hi guys.
Is there a Bug in Channel Delay?For example:
On Input 1 i got a guitar. This Input is routed to Channel Fader 1 and 2 and from there to the Main L/R and also to a Stereo Monitor Mix. On Channel Fader 2 i set a Channel Delay for 8ms to get the guitar into a Stereo Panorama.
When Listening to L/R Mix via Headphones or directly on the PA, the delay Setting for Fader 2 works perfectly
The Problem is that the delay is not transmitted to the Stereo Monitor Mix!
Is that Bug or is it a Feature?
Kind regards
Andy
@Some1else
By default, input channels are sent to Auxes Post-PEQ, which is before the compressor and the delay in the signal path.
As shown here - https://www.allen-heath.com/media/SQ_ReferenceGuide_V1_5_0.pdf#page=109&zoom=auto,-361,1
You can change the channel source from the routing page, as described here - https://www.allen-heath.com/media/SQ_ReferenceGuide_V1_5_0.pdf#page=40&zoom=auto,-361,573
In this case, to include the channel delay, set channel source for your monitor Aux to Post-Delay.
@KeithJA&H Thank you for your quick response on that. I ´m sorry for bothering again. When opening both links I starting from page 1 of the manual. Can you please tell me the pages?
Thank you in advance
Andy
The links mention the pages:
The signalpath is on page 109(actually the diagrams start at page 110 )
The routing change on page 40
Yesss. There we go :slight_smile:
Thank you guys!!!
