I have a scenario I wonder if anyone else might have tried to implement…
With so many now streaming audio online, I have a church who are looking to have a system where when the mute button is pressed on the SQ6 that this also lights up an external wall mounted Panel with the presenters mic number in red when they are muted. So, if mute Lapel 1, the box on the wall shows that lapel 1 is lit up red. Its a prefabricated metal box like an On Air box.
Has anyone come across essentially a MIDI to voltage switch relay unit that could receive a MIDI command from the SQ and trigger a relay switch to turn on an external light source?
interesting idea but what do they do with that box on the wall that has the light ?
do they want to know their mike is safe if they are making comments they dont want heard?
we group the rf mikes and can see the mute buttons lit up to know who is live and who is muted
if you really NEEDed this it would not be hard to convert note on to light on using some existing device
interesting. we have on/off switches so they can control when they are live.
our folks just turn the mikes on when they are on stage and we handle muting/unmuting from FOH.
I guess if there were a need they could toggle them during the performance too.
I have trouble envisioning how that could work except in a small studio.
No way they could see it from the stage in our church.
Here is company that make all kinds of MIDI control interfaces, about half way
down the page they have a few that take a MIDI command convert that to a contact
closure.
Do you have multiple presenters on stage at one time taking turns speaking during
a presentation?
What is the presentation format and setting?
Normally I don’t hard mute mics during a presentation but rather use the faders
to bring mics up and down.
That way so if you slightly miss a cue it’s smoother that just turning a mic on in the middle of a word.
I think this should work! - Give us info about your experience.
To get the 5 pin Midi Signal out of your SQ - you’ll need the bomeBox.
Or you’ll use a Computer connected to the USB or Network of your SQ.
But the Bomebox can also connect via Wifi to the SQ - I’m playing actual a lot with this little Box - it’s amazing https://www.bome.com/products/bomebox
