Channel muted by themselves...
Doing a conference on a QU-24 and just had three channels mute by themselves…
Not part of a mute group, no scene recalled, no iPad in use… One minute they were live, the next they were muted!
Some PC/Mac connected to the USB port with an active application capable of sending MIDI? Channel Mutes can be controlled via MIDI using regular Note ON/OFF events.
Was the network connected to anything?
No USB connected, network port was connected to a wireless router (no internet) but no wireless devices
Hmm, just wondering how the Qu would respond to port scanning attacks. Hopefully your WiFi is properly secured and does not broadcast its SSID. In a public space you never know who is in…
This is the reason I have always been a bit saddened that the desk has no authentication at all on the network side.
I kind-a sort-a trust my QU WiFi, but…
What are the odds that someone sinister was close enough to get in? Not likely. I vote for something internal.
Chances to get into the WiFi totally depends on the security setting. WEP and WPA are nowadays rather easy to infiltrate, WPA2 is the least one should use. Hiding the SSID (non broadcasting) adds another barrier (out of sight - out of mind).
Once a device is connected to the WiFi network, communication with any other node is easily possible. The Qu with the total lack of authentication may interpret any incoming packet (i.e. sent by some port scanner utility) as control data.
I know there are many people around who everywhere and anytime try to find open WiFi networks and “look” whats behind. Not necessarily bad intention to hack the Qu, but maybe just a bad coincidence of packet content.
@Dave: Hmm, which firmware version are you running on your Qu24? Maybe the recently fixed sporadic-fader-movement-bug can do more than just fader movements.
Andreas…
My thoughts exactly. As long as there’s a device connected to the network port you cannot rule out the possibility of the board interpereting any activity on it as a control command.
The first trouble-shooting step is simply to disconnect the network port device.
Odds are low, but non zero. And sinister isn’t a requirement - I’ve no idea how the QU responds to random stuff on the NIC, maybe a jumbo frame causes an overflow somewhere, maybe anything…
Once you set up passwords for the three user levels (admin, standard, and basic), anyone connecting with an Internet device will have to log in to the mixer.
They will with latest firmware - but afaik no one has done a full pen test against the nic of a QU
