Channel naming in mixpad a
The naming and color selection box should be moved to a higher position on the screen (at least on iPad). the keyboard is blocking half the naming and color selection window as well as the control buttons (see attached image)
Though that app is not made by A&H…
Yes it! Sorry - thought it was something else!
Hmm, „on my PC it works.“ (iPad Air2 V12.4.1 with lates MixPad App, Lenovo YT-X703F V7.1.1 both with MixPad V1.4.3, offline as well online)
it works on ipad as well, the problem is more of a design issue - the sofware keyboard covers the dialog box, so the dialog box should be moved so it can be completely visible even when the keyboard is activated. as it is now one has to remove the keyboard from the screen in order to sve the setting or choose the lowest row of colors.
it does not happen on my ipad
everything is ok with the renaming dialog here
huh. which ipad are you on?
See attached image of my iPad
So I’m on an iPad Air 3rd gen. Could that be the reason for this?
This is no longer an issue after updating to iPadOS
