So, this week as our team went to record (video) the pastor’s sermon for our on-line Sunday presentation, I was readying our system (QU-32) and the pastor’s lav channel suddenly was no longer accessible in the FOH speakers. We didn’t fully need it for that as we are not meeting in person for the time being (COVID-19), but the pastor likes to have a touch of his mic in the house system for a realistic service feel. The oddity is that his lav channel is routed through every mix that we have on the board and is working on every feed except for the FOH.
We’ve had this board for over a year and a half (and love everything about), but this is the first time we’ve had this issue. While not being the sharpest tool in the shed, I set this system up initially (going from an analog desk to digital) and have been fairly proficient in operating it, but this has me stumped. Any help/direction would be appreciated.
Nothing has (knowingly) changed since I set up the board. With the down time, I’ve been experimenting with different EQ set-ups on our vocals and drums, but nothing beyond that.
Since we began videoing our worship and sermon for on-line distribution, I set up Mix 7-8 for an audio feed to our camera for recording and that has worked as it should for three weeks while our pastor’s mic came through the FOH as desired for the first two weeks before disappearing before yesterday’s session. I’ve been the sound tech for all three weeks of video recording so that variable has not changed.
I’ve done a visual comparison of pastor’s channel compared to our other inputs and everything looks identical channel to channel.
I’m not doubting that I must have done something…it just wasn’t done purposely/knowingly. I’m always the first to own up to a mistake (it’s always the sound guy’s fault anyways, so why fight it?). And I really don’t think it could possibly be hardware failure. Otherwise, I’d not be getting that mic working fine on a plethora of other feeds it’s also sent to.
No to working off an iPad today (or in the last several months actually).
Checked my routing screen while there earlier today and the sends to all of my mixes were in the “ON” selection.
I’m home now so no access to my desk, but I’ll check on the suggestions given when I go back in to troubleshoot early next week.
Appreciate the suggestions! I’ll be back once I’m in front of my mixer again.
The battle is not always to the strong
the race is not always to the swift
but my bookie says that is the way to bet
You did print out the master configuration sheet didnt you?
So print it out again and compare it
Or does AH not provide such a simple way to document the device and how it is set up???
If not then I have to ask why such a necessary document is not feasible.
No such configuration sheet that I’m aware of. Then again, getting this mixer up and running on the go (mixer arrived late on a Thursday afternoon and was told “…and we need this up and running for rehearsal by 8am Sunday”) was a minor miracle in and of itself. Getting the base functions enabled and routed correctly was good enough to get us started and I’ve continually expanded my knowledge of the mixer moving forward (while still only scratching the surface of what it can do).
But, obviously, I’m still very much a neophyte in comparison to others here…
Select the main LR strip. On the left side of the board, hold down the green Assign button. Is the lav mic channel select button lit? If not, while still holding down the Assign button, press the channels select button to assign it to the LR mix.
The symptom does resemble your using the wrong layer to mute/set some option.
Trace the lav mike from the Pastor through the RF receiver to the board input
through all the entire path the signal takes until it gets to the LR output.
I have no idea what you mean to FOH as our QU does not have anything anywhere labelled FOH.
I suspect people are assuming you meant LR output but do tell us exactly what output you meant by FOH.
is it possible that it gets assigned to a DCA and the DCA is down?
so the DCA overrides the fader level
go to the routing screen, select the DCA tab
to use DCA you need to assign them to the surface on the user layer</blockquote>
Thank you Steffen! Our wireless lavs are assigned to a DCA group for holiday productions. In setting up additional audio FX for our video stream prior to last week’s recording, while raising my FX SENDs on the sub level, I absentmindedly decided to pull the DCA1 MASTER down.
