Channel select as (bidirectional) MIDI control message
Using the MIDI message functionalities is great to create custom setups or control of external gear, but alas it is not possible to manipulate channel-specific parameters as other channel-specific in-console parameters are manipulated: by selecting a channel and then using the respective controls (such as dynamics, filter, etc).
The channel-selection is available in the SQ Mixpad app which relies on the non-disclosed protocol, unfortunately.
This is a limitation of the possibilities at hand.
If the channel selection would be accessible as MIDI message then external setups can build upon the very same idea of thus manipulating channel-specific parameters using the custom rotaries etc.
A very small change with a rather big impact.
I believe you can get there via Mixing Station.
That’s a good input, thank you!
