I want to save individual channel strip settings to import/export as needed. Is there a way to save an entire independent channel strip that INCLUDES ALL settings. Input gain, eq, compression, gate, name, etc to the library. What I found did not include ALL.
Thank you!
SCENES will save channel strip settings. Not sure that you can do this per channel though…you’d probably need to do one Scene for each strip if that’s the way you want to go.
I think you may want to look at the Processing Library. You can save custom
channel strip processing set ups in the library and then recall them as needed
to the channel or channels you need to use them on.
Page 35 of the user manual.
Hey Dick ! Good to see you again, I was kinda worrying about you as we hadn’t seen you around for a while…
Giga
