Small background:
dLive is perfect for routing and merging any other consoles on big festival. dLive have much channels, analog and digital inputs, mixes and expansion cards. And all of this perfect for better festival master console. But…
But, i can’t route channel to matrix. Yes, i can send channel to group or master, and then to matrix. But i need use more mixes. This feature not difficult and don’t add problem. Thank you.
If you route an input to a matrix does that not make the matrix a mix bus?
After all you have 64 mix buses surely you could commit one to cover your need?
Yes, that is how I remember from old days- matrix is mix from buses. Adding inputs to this would create something new- a hybrid between aux and matrix.
Hmm… How do you mean? You must be able to safe and mute your matrixes without problems?
Tho, I understand a need to be able to send a processed channel to matrix. A workaround until that can be made could be to make a direct out from a channel and route it back to a matrix ext in? Hardwire, will waste some connections but maybe the best solution to it now. If not, I may not understand the problem.
Cheers //Gustav
If you mean having several inputs active to a matrix, use groups to have redundant audio flow. Sure, it’s not a route everything to anything matrix, but since there are a bunch of busses availiable on the console, routing by bus input>bus>matrix might work fine in many scenarios.
Still just a tip to make it work. It’s not prefwrred since it uses up busses, might be tight when you do need them all.
Yes, you can do that well with aux. an aux does not always have to be prefade
Nevertheless, this question about channels-to-Matrix will keep reappearing, because many technicians are so used to it from Yamaha.
it might therefore be a good idea to implement this in dLive, so that this theme, which has been recurring for many years, can finally be brought to an end.
