The channel to mix button should be ade a latching + momentary button in the same way the “talkback” can be set. This button is very useful when mixing monitors and would be even better if it could be set to latching.
+1
We had that discussion before – it was named a bit different…
Are you saying there is a solution for this? If so, what is it called and where do I access it?
Its still a feature suggestion…
