For recording straight to CD, I regularly use two mics on a small instrumental (brass and winds)ensemble that doesn’t need to be amplified, in addition to choir and electronic instruments that do need amplification. My record mix consists of two auxes, and the sends are Rotary, so the only solution I have been given to getting these two sources to the record mix is to have them Pre-fader and select the Auxes and turn the Rotaries to bring them into the record mix. That’s far more tedious than in the analog world sliding the two faders up - since you can have the channels/strips not assigned to the mix. Am I missing something? Suggestions?
John Cox
Fuquay-Varina Baptist Church Audio Team
iLive 112-T/idr48
